LabWindows/CVI
CVI+TestSTand - UIR
I'm new to these programs, so, I hope there is an easy solution to my
question.
I'm trying to build an application using CVI+TestStand.
Instead of using the provided TestStand UIR and providing that I'm not
capable of modifying it or build a new one, can I make my own UIR with
CVI and use it instead?
In that case, how TestStand interfaces with the CVI UIR?
If the above is possible, is there an advantage to use TestStand at
all?
Rafi
(3,030 Views)
Rafi..
In the TestStand directory you should find example code for the CVI user interface which will help you understand how it works.
If you are using TestStand 3.0, it has some great documentation about the User Interface API which has been greatly improved over an already great API in previous versions.
See if you can find the example stuff, and let us know how you get on.
But yes it can be done, and its not too difficult either.
(If you installed the examples when you first installed TestStand).
Regards
Chris
(3,030 Views)
