LabWindows/CVI
How can I get a value with a pointer to void from the GetCtrlVal-function??
I'd like to get a value from the GetCtrlVal-function with a pointer to void and pass it to the SetCtrlVal-function. Does this work and how do I have to pass the pointer to the function??
(3,070 Views)
Andy,
All you need to do is cast the pointer to the appropriate type when passing it arround. Here is a small example:
void *temp;
temp = malloc(sizeof(double));
GetCtrlVal (panelHandle, PANEL_BPM, (double *)temp);
DebugPrintf("The value is...%f", *((double *)temp));
SetCtrlVal (panelHandle, PANEL_BPM, *((double *)temp));
free(temp);
Make sure that you allways have the required memory space allocated for the data type that you are using.
Hope that helps.
Juan Carlos
N.I.
(3,070 Views)
Thanks for your help, it works.
(3,070 Views)
