09-23-2005 10:00 AM
09-26-2005 03:06 PM
Hung,
VISA should be able to handle 1 Mbps without an issue. The real question is can your prallel port? I would first verify that your port can support that high of a transfer rate, then you could use VISA with CVI. I would download the latest VISA drivers, which install with support for CVI. Once they are installed you can open CVI, go to Help >> Find Examples and browse for Hardware Input and Output. You should have the option to select some serial examples for you to use.
Hope this helps!
Andy F.
09-27-2005 08:12 AM
