LabWindows/CVI
CVI and 1Mbits data stream
Hello
I have read about lab Windows CVI VISA lib, which is designed for serial instruments.  I have a burst of 1M bits/sec serial data coming off a interface board,  I would like to know if CVI VISA can handle that high a data rate and how should I set it up?  Are there any examples or tutorials that I can learn from?  My plan is that if I can use CVI to collect the burst of data maybe thru the PC parallel port, which has extra pins for handshake signals in case I do need them, and then parse the collected data in between bursts.
Thanks in advance for any inputs and comments
Regards
Hung
(3,356 Views)
Hung,
VISA should be able to handle 1 Mbps without an issue.  The real question is can your prallel port?  I would first verify that your port can support that high of a transfer rate, then you could use VISA with CVI.  I would download the latest VISA drivers, which install with support for CVI.  Once they are installed you can open CVI, go to Help >> Find Examples and browse for Hardware Input and Output.  You should have the option to select some serial examples for you to use.
Hope this helps!
Andy F.
(3,328 Views)
Thank you Andy, I will look into it.
Hung
(3,311 Views)
