LabWindows/CVI
CVI and DTMF
I am using a Dialogic modem card with CVI.  It is a modem/telephonics card to make and receive calls.  A complete DTMF read/send section is available.  Not cheap, but very powerful.  It comes with a DLL that can be accessed via CVI (create DLL import library, etc.).
Regards, Dave Eaton
Message 11 of 12
(1,157 Views)
Hi Jon,
I wrote the code in LabVIEW, but since it's all DAQmx calls, all you need to do is copy over the code VI by VI into its text-based equivalent (DAQmx is the same function set regardless of programming environment).  The text-based DAQmx code Reference help is available on your computer Programs>National Instruments>NI-DAQ>Text-Based Code Support.
Message Edited by Knights Who Say NI on 07-09-2009 12:18 PM
-John Sullivan
Problem Solver
Message 12 of 12
(1,136 Views)
