LabWindows/CVI
CVI executables causes Access Violation 0xC0000005 on Windows 10 Anniversary Update.
I'm trying to figure out the take-away from this thread, as it relates to development and target machines.
I can delete those fonts on my development PC, but under what scenarios might a target PC run into this issue, and how can I avoid it?
Message 11 of 35
(7,245 Views)
Hi Ian-
It seems like we have several options:
 1. Ship with a copy of the runtimes in our application directory (minus the fonts). This could work but is inelegant, and would mean any common runtime upgrades at that point would not apply to this installation.
 2. Ship with something that can scrub the fonts from the windows directory. This is unacceptable, for us anyway, as it is assuming the user has no other CVI applications that use those fonts, and if they did we'd be breaking another app.
I don't like either option. And option 1 doesn't fix our applications already out in the wild.
I am crossing my fingers for a run-time update soon, as every application we've shipped in the last decade or so will now be crashing on exit.
-Baker
Message 12 of 35
(7,241 Views)
Under what circumstances do those problematic fonts get placed into c:\Windows\SysWOW64\cvirte\fonts and c:\Windows\System32\cvirte\fonts ?
  • Target machine installation of RTE only?
  • Distribution kit installs RTE in default location?
  • Distribution kit installs RTE in application directory?
  • other scenarios(?)
  • Does it depend which version of CVI / RTE is used?
Defining these details is necessary for developers to anticipate and to manage the problem.
Message 13 of 35
(7,165 Views)
On my development machine this bug occurs only when I have NOT running CVI IDE, and it happens for debug and release executables.
Removing only ni7seg.ttf font from SysWOW64\cvirte\fonts cured the problem.
nisystem.ttf appears to be unrelated to this bug.
Windows 10 Pro / 1607 / build 14393.187 / x64
LabWindows/CVI 2015SP1 15.0.1 (239)
Carlo A.
Megaris
Message 14 of 35
(7,051 Views)
This problem just started for me after Windows 10 updated itself today, and removing the fonts does seem to fix it. Thanks for the suggestion.
Message 15 of 35
(6,963 Views)
I correct myself. On another attempt I had to remove BOTH fonts to avoid the problem. I don't know why it worked with only one font removed.
Carlo A.
Megaris
Message 16 of 35
(6,799 Views)
The solution of removing both fonts works fine, but as a different workaround without removing any files just add the following line code soon after the RunUserInterface(), that means as soon as the application is going to be quit:
RunUserInterface();
SetSystemAttribute(ATTR_TASKBAR_BUTTON_VISIBLE, 0);
Cheers
Message 17 of 35
(6,745 Views)
RunUserInterface();
Cheers
This does not appear to solve the issue for us, can anyone else provide feedback on this method? Removing the fonts does solve the issue for us. However, we do not believe removing said fonts/files on so many deployed installations is practical or wise. Hoping for yet another alternative.
Message 18 of 35
(6,324 Views)
Chaddwickky, adding
after RunUserInterface(), so it's executed when the program terminates, solves the problem for all my programs.
I think it will fixed in next service pack: after all, it's only a cosmetic issue.
It's ugly and confusing for the user, but it does not ruins the functionality of the program.
Carlo A.
Megaris
Message 19 of 35
(6,311 Views)
Thank you Carlo!
We did try that. I'm rather surprised it didn't work. We will revisit it again given we have confirmation that others have replicated the fix with success. I was looking for any indication that the SetSystemAttribute method was a selectively applicable fix. Will post with any updates as discovered. Thank you for the time.
Message 20 of 35
(6,311 Views)
