LabWindows/CVI
CVI program to HP1333 started hanging.
I have been running an application for several years. Now the program hangs randomly. Must do CTL-ALT-DEL and stop program. When I run RESMAN, it hangs at 1 second clearing "SYSFAIL". Only way to clear is restart computer. Have swapped PCI card, slot 0 card, cable, backplane, HP1333A, reloaded program, scanned hard drive (no errors). What am I missing?
(3,188 Views)
Jacque,
Has anything changed in the system over the years? Something must have changed in order to introduce this different behavior. What PCI card do you have in your system? I assume that you are using MXI/VXI. What is your CVI code actually doing? Has the code changed at all? I would recommend running NI-Spy while the CVI code is running to see if we can track down any abnormal behavior (NI-Spy will log low-level driver calls):
Performing a SPY Capture
Craig H.
NI Applications Engineering
(3,173 Views)
