LabWindows/CVI
OSError: An unexpected error ocuured from the operating system... DiG_Block_in return value (-10856)
I need help to solve this error. I am using the DIO-32HS and AT-AO-10 cards on windows '98 OS.
Tesfaye
(2,945 Views)
Hello Tesfaye,
First, I would recommend trying the customer suggestions on the following post. This suggestion involves manually setting the IRQ and DMA channels.
Also, I would recommend updating your system to the newest NI-DAQ drivers supported by your operating system and hardware. The most recent version for your setup is NIDAQ 7.1.
Thanks and I hope that helps!
Wendy L
LabWindows/CVI Developer Newsletter
(2,932 Views)
