CVI2013 f1 and preprocessor ## directive
CVI2013 with f1 gives build error for preprocessor ## directive (token concatenation).
See attachment
Vix
Using LV from 7
Using LW/CVI from 6.0
(4,965 Views)
I don't understand what you mean with that link, sorry.
Could you explain it, please?
Vix
Using LV from 7
(4,890 Views)
Accepted by vix
You are wrongly using the ## operator.
The ## operator is called also "token pasting operator" and its purpose is to tell to C preprocessor to concatenate two tokens.
You want simply to concatenate two strings: you don't need any special operator:
#define LocalDir   "E:\\"  SharedDir        // define
Carlo A.
Megaris
(4,877 Views)
Now I understand what you mean, and I tried that your suggestion works in CVI 2013
#define str1    "abcd"
#define str2    "efgh"
#define concatenated_string    str1 str2   //using a space character between the 2 strings
I don't know why ## has been working for string concatenation since CVI 6.0 to CVI 2012 SP1 Smiley Surprised
I've been using it since years (I supposed that a string is a simple token, but probably it isn't)
Vix
Using LV from 7
(4,807 Views)
Hi
Keep in mind that this is a general feature of string literals, and not something related to preprocessor directives, so you could, for example, write something like this:
printf("this "
       "is "
       "a single "
       "long "
       "string");
Carlo A.
Megaris
(4,797 Views)
