LabWindows/CVI
CVI8.0 can not work with Clearcase while CVI6.0 can, with the same PC
Hi CH,
That's great that you were able to get ClearCase working with LabWindows/CVI 8.1. Did you change anything in LabWindows/CVI 8.1 compared to earlier LabWindows/CVI version to get it to work?
Best Regards,
Jonathan N.
Message 11 of 12
(1,029 Views)
Hi Jonathan,
in fact, I did no further changes.
After installation of 8.1, restart of PC, I did run CVI8.1. You'll be asked if the previouse configuration of the IDE (8.0) should be used or not. In my case I decided to use the previouse settings.
I did then load the Project directly from the VOB (last setting).
Next step was, Edit»Project»Source Code Control Options, doing a few clicks and that's it. (pls. see attachement).
Kind regards,
Claus H.
Message 12 of 12
(1,011 Views)
