 CVI-User
			CVI-User
			02-21-2006 06:05 AM
 Andre_Saller
			Andre_Saller
			02-22-2006 07:18 AM
02-22-2006 08:22 AM
02-23-2006 08:33 AM
02-27-2006 02:40 PM
The new look of the toolbar is on by default. If you do not set the style, the style you get is (TOOLBAR_VAL_FLAT | TOOLBAR_VAL_NEW_STYLE). If you want the old look, do not bitwise or in the new style constant when you set the style. The default style is the same style used by the CVI environment.
I should also point out that to get the full benefit of the new toolbar style, you have to use images with a transparent background (via a transparency mask or alpha channel).
Hope this helps,
-alex
