LabWindows/CVI
Callback does not respond to EVENT_COMMIT seems to require EVENT_MOUSE_POINTER_MOVE
Callback does not respond to EVENT_COMMIT. Why not?
Responds to EVENT_MOUSE_POINTER_MOVE.
int CVICALLBACK DISPLAY_COAS (int panel, int control, int event,
        void *callbackData, int eventData1, int eventData2) {
    int i;
    switch (event) {
        case EVENT_MOUSE_POINTER_MOVE:
        case EVENT_COMMIT:
            Parsing_result[0] = '\0';
            for (COMPANY_INDEX = 0; COMPANY_INDEX < NUMBER_OF_COMPANIES; COMPANY_INDEX++) {
                                Number_of_CofA_entries = Company_list[COMPANY_INDEX].CofA_map_SIZE;
                                for (CofA_map_INDEX = 0; CofA_map_INDEX < Number_of_CofA_entries; CofA_map_INDEX++) {
                                    for (i = 0; i <CofA_map[COMPANY_INDEX][CofA_map_INDEX].level; i++) {
                                            strcat(Parsing_result,"      ");
                                    strcat(Parsing_result,CofA_map[COMPANY_INDEX][CofA_map_INDEX].Account_name);
                                    strcat(Parsing_result,"\n");
            break;
  MessagePopup ("Parsing result", Parsing_result);
    return 0;
(3,956 Views)
Which mode is your control set to? To have it respond to EVENT_COMMIT events it must be set in hot mode; every other mode prevents it from firing commit events. Also, which control is this callback installed on?
In every case, MOUSE_POINTER_MOVE is too general a event for this task: it is fired on every mouse movement on the control; you can use EVENT_LEFT_CLICK instead.
(3,953 Views)
Accepted by topic author cegcs
Thank you for your prompt response. It seems that part of the problem was that the line               MessagePopup ("Parsing result", Parsing_result);
should have been inserted above the break; so the popup would only occur when an EVENT_COMMIT had occurred. The way I had it (below the break;) I would see the popup as soon as an EVENT_MOUSE_POINTER_MOVE occurred and there was never an opportunity to respond properly to an EVENT_COMMIT. Pilot errorSmiley Sad
cegcs
(3,880 Views)
I would give a kudo but I don't know howSmiley Sad
(3,878 Views)
Thank you for asking: you simply have to click on the highlighted symbol
(3,869 Views)
Done. Thank you. I also experimented with the control mode and it is as you say.
cegcs
(3,859 Views)
Roberto,
 I'll give ya Kudos on this even if it is not my post! 🙂 Thanks for the info! Cheers!
ChipB aka ASIC LabRat
(3,850 Views)
