LabWindows/CVI
How do I build a VB.Net Compatible DLL in CVI 2010?
I have some old DLL files that I built using CVI 6.0 (or thereabouts) that were VB6 compatible.  I built them by changing the calling convention from _cdecl to _stdcall, and exporting the header files containing all DLL constants and functions to VB Compatible BAS files.  We haven't used these libraries in a long time and now we have a customer who wants VB.Net compatible dll files of the same project.  I was wondering how to go about building them in CVI 2010.  Is it the same process?
Thanks ahead of time for any help.
Judy
(3,338 Views)
Hi Judyh,
I found an article on creating a CVI DLL for Visual Basic. It is listed below for your reference.
http://digital.ni.com/public.nsf/allkb/2B42270EAC4A109C862569AE006253C1?OpenDocument
It looks like the procedure is still the same.
I hope this helps.
Josh L.
(3,325 Views)
That doesn't mention VB.NET it doesn't look like to me, though from the CVI created DLL side things may be the same as with VB6.
You can invoke a traditional, non-ActiveX DLL created in CVI from a .NET language by using P/Invoke (Platform Invocation Services).
Here's an example adapted from C# 4.0 In A Nutshell from O Reilly.  VB.NET is similar.
using system;
using System.Runtime.InteropServices;
class Test {
  [DLLImport("myCVIDLL.dll")]
  static extern int myCVIdllFunction (int myParam);
  public static void Main() {
        int iReturn = myCVIdllFunction (1);
To build the CVI DLL, I'd suggest following the same calling convention as you did for the VB6 compatible one.
I've always used
INT DLLEXPORT DLLSTDCALL myCVIdllFunction (int i) { ... }
for a DLL function signature that I wanted to be available from VB6.  I usually include a type library resource too, I don't know if .NET will use one or not.  It should be harmless enough to include one and see what happens.
(3,321 Views)
