LabWindows/CVI
Callback registration problem with Windows Media Player ActiveX control
Hello,everyone:
      I was adding a WMP ActiveX Control into my uir file .  When I tried to register callback functions for control events ,  the  callback registration functions always returned error code -2147220992, which probably meant "unknown error" ;   The registration seemed to be failed, because the callback functions were not fired.
      I tried with other kind of ActiveX controls and the registration of callbacks was successful.
      I am using Windows 7 and CVI2009. The version  of the WMP is 12.0.7600.16415( Obtained with WMPLib_IWMPPlayer2GetversionInfo() function  ).
     Could anyone offer any possible causes and solutions for this problem?
Thanks!
(3,687 Views)
Hi Chen,
Have you tried this example program? I have CVI 2009 and Windows 7 and this works without any problems.
Cheers,
(3,650 Views)
Hi, Michael
The  example program  works well. But there is no Callback registration function called in the program.
When I call callback reg function as  "  WMPLib_IWMPSliderCtrlEventsRegOnondragend (...)" , it returns an error.
There are callback reg functions for different events (see the picture below), but only those for "_WMPOCXEvents " work without problem. Others return errors.
I've found a way to avoid such problem in my program,  but I think I should get you informed about it. Thanks for your attention!
Callback reg func for different events
(3,632 Views)
