LabWindows/CVI
Found driver for Agilent E3633A but it is for V6.0 LabWindows. Is it ok for V8.5.1?
I have a Agilent E3633A power supply that I am trying to communicate with on GPIB. I have a Agilent 82357B USB/GPIB that connects my PC to the power supply. I am having trouble talking to the power supply. I saw some posts on the subject and saw there is a driver for the E3633A. I downloaded it. The download page said this was for LabWindows V6.0. Will it be ok to install it for LabWindows V8.5?
I am also looking for some code examples that use the Agilent 82357B USB/GPIB to communicate with instruments. Have not used GPIB on LabWindows before so I am struggling a bit. Any suggestions are appreciated.
thanks in advance,
Don Pearce
(3,575 Views)
The power supply driver is probably fine, especially if you have the source code with it.
If it is a VISA driver, you will need the version of VISA that is compatible with your interface. In this case, with your Agilent interface. I personally have no experience with that equipment as I have always used NI GPIB interfaces and NI-VISA to keep things simple.
You may need to contact Agilent technical support for the interface issues.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(3,574 Views)
Did you download the driver from IDNet or Agilent?  Some customers have seen issues when they have both NI VISA and Agilent VISA.
(3,542 Views)
The drivers I dopwnloaded from National Instruments fixed my problem. When You install Agilent Library Suite 15.0 the setup documentation tells you how to make Agilent VISA compatible with NI VISA>
(3,534 Views)
