Calling the SDK Help causes an error in CVI.
When I try to call the Win SDK Help from the menu bar under LabWindows CVI ver. 5.5.1 I get the following error:
"Impossible to open file: e:\measurementstudio\cvi\sdk\help\platsdk.col"
Notice that the mentioned file in reality IS in that directory. How to overcome the problem ?
Thanks in advance,
Marco
(2,960 Views)
Marco...
It works on my PC, and guess either your installation is screwy, you might want to check the registry settings for CVI, or do a re-install.
I have not heard of this one before, and there is nothing in the archives about it.
It might be the "e" drive that is hosing things up, since mine is installed on "C" I can't try it out.
Sorry I can't offer any more suggestions.
Chris
(2,960 Views)
