LabWindows/CVI
Can CVI be optimized to match the speed of standard C?
Can CVI be optimized to create exe's that run as fast as a program generated
by normal C compiler? Or is the overhead of using the runtime and the CVI
compiler prevent this? I have been doing some benchmarking with various C
compilers and CVI is by far the slowest.
(3,173 Views)
CVI does support external compilers, and they typically include optimization - something that the CVI compiler does not.  Check out Options >> Build Options and then "Compiler for Release Configuration" in the lower right.  That screen also has a "Help" button for the relevant online help.  I believe that several optimizing C compilers are a free download.
Hope this helps.
--Ian
(3,139 Views)
Yes, I have experienced this. and the compiled EXE file size is another probelm: if you use a .fp file, the size of the EXE file will increase a 10 --500K, even you only use one function of .fp. I don't know why NI don't  optimized.
(3,107 Views)
