LabWindows/CVI
jsockwndyclass
I am developing User Interface using LabWindows/CVI 8.0.  The UI is a TCP server and can call any test program as a client.   This is also a multi-threaded application.  If when debugging I abort the application I will get a message when I finally log off my computer asking if I want to end the process JOSOCKWNDYCLASS.   Sometimes I will get the message several times before I can log off.  I suspect this has something to do with not cleaning up (closing threads, closing connections, etc.) because I abort the application.
Does anyone know what is going on and why any stray processes are not cleaned up by LabWindows when I exit LabWindows?  What does jsockwndyclass indicate?  Thanks
JJT
(2,978 Views)
Hi JJT,
CVI uses Winsock underneath its TCP function calls, so this must be a remnant of the winsock process that is left over from aborting.
Cheers,
David Goldberg
Software R&D
(2,952 Views)
