LabWindows/CVI
Can CVI be used to measure relay bounce with TDS2012B o-scope?
Can CVI be used to set up and querry the Tektronix TDS2012B scope to measure relay bounce time?
All input is appreciated!
Thanks!
Randal
(2,837 Views)
searching the NI instrument driver network page https://www.ni.com/en/support/downloads/instrument-drivers.html/ yields the following link for the mentioned scope:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E94FE659CE034080020E748...
Using this driver should allow you to conveniently read a waveform that you can evaluate using e.g. the Advanced Analysis Library.
Wolfgang
(2,833 Views)
