LabWindows/CVI
A section of a panel
is it possible to hide/display only a section of a panel in labwindows CVI?
thanks a lot
(3,021 Views)
Hi sahin,
What do you exactly want to do? What do you mean by a "section of a panel"?
Do you actually want to hide a group of controls?
If so, you can;
- put those controls' ID's in an array and call SetCtrlAttribute (panel, ctrl_arr[i], ATTR_VISIBLE, 1 /*or 0*/) in a loop,
OR
- put those controls on a transparent tab panel (you can hide tab labels if you want) and display/hide the tab panel
Hope this helps,
S. Eren BALCI
IMESTEK
(3,019 Views)
i want to use two different panels commutatively, and these panels heve common graphs
I want only cotrols other than graphs will change when I exchange graphs. I know it's possible
to use whole program in a single tab and controls other than graphs under a tab control,
but this metod makes it difficult to corect control IDs, panelHandles, etc.
thank you very much
(3,017 Views)
Hi Sahin,
Please refer to Ebalci's post. From what you have described, his recommendation seems to be the best option. Good luck!
Jackie
DAQ Product Marketing Engineer
(2,998 Views)
