LabWindows/CVI
Window and content rescaling according to display resolution
I wrote a LabWindows Programm and drew an according user interface for it. The Software is now used on a different computer which has much lower display resolution. This leads to the problem that not all of the content is visible.
Is there a way to scale the user interface relative to the available resolution without writing lots of code?
thanks in advance,
Christoph
(2,958 Views)
Accepted by topic author MrWhite
You can use the Resolution Adjustment and Scale content on resize attributes of the panel, together with SetPanelSize, to obtain a complete scaling of panel and controls depending on the display resolution you are using. See this knowledgebase entry for additional details.
(2,954 Views)
