LabWindows/CVI
Can I replace SCXI-1600 with USB 6259 DAQ to control SCXI modules?
(3,817 Views)
Hello Robert,
The short answer is no.  As noted on page 24 of the M Series User Manual, "SCXI is not supported on the NI 6221 (37-pin) or USB-625x devices."  For USB connectivity, you can still use the SCXI-1600.
(3,801 Views)
Hello Jarold,
NI Measurement & Automation catalog (2006), page 183, Table 2, suggests the following devices could be used to control SCXI modules: SCXI-1600, M Series DAQs, PCI 68-pin E Series, DAQCard 6036E, DAQCard 6062E, etc.
I wanted to verify I can surely use either USB 6259 DAQ or, 68-pin PCI 6221 DAQ to control SCXI modules. Would you please verify again for me?
Thank you in advance.
Robert
(3,787 Views)
Hello Robert,
You can use the 68-pin PCI-6221 (not the 37-pin version) to control your SCXI modules.  You cannot use the USB-6259 to control the SCXI modules.  Again, for USB connectivity, use the SCXI-1600.
(3,753 Views)
