Can I use SQL Toolkit with SQL ServerExpress 2005?
I have just tried the SQL ServerExpress 2005, I wonder that the CVI 8.0 can use SQL Toolkit with this Server?
(3,433 Views)
Hi plit string,
You can use the SQL Toolkit with with ServerExpress 2005. The toolkit uses a DSN to connect to the database.
Test Engineer - CTA
(3,417 Views)
Thanks, I will try ASAP Smiley Happy
(3,413 Views)
