Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can I use SQL Toolkit with SQL ServerExpress 2005?
plit string
Member
02-01-2007
08:43 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have just tried the SQL ServerExpress 2005, I wonder that the CVI 8.0 can use SQL Toolkit with this Server?
0
Kudos
Message
1
of 3
(3,526 Views)
Reply
Re: Can I use SQL Toolkit with SQL ServerExpress 2005?
Jon_M
Member
02-02-2007
01:18 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi plit string,
You can use the SQL Toolkit with with ServerExpress 2005. The toolkit uses a DSN to connect to the database.
Test Engineer - CTA
0
Kudos
Message
2
of 3
(3,510 Views)
Reply
plit string
Member
Author
02-02-2007
01:26 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks, I will try ASAP
0
Kudos
Message
3
of 3
(3,506 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
