LabWindows/CVI
Can I zoom/pan on two graphs at the same time?
I have two separate graphs both with zooming enabled. I want to be able to have my mouse cursor on one of them, but when I do the zoom thing (ctrl + right click) I want BOTH of the graphs to zoom in. Is this possible? I'm using CVI 5.5
(3,515 Views)
I understand that's not so elegant, but you could try a workaround like this one:
1. DO NOT enable zooming on the graph
2. Instead, write your own routine to zoom both graphs.
Here you'll find some sample code to zoom the x-axis of a graph; it's easily expandable for panning, for the y-axis and for the other graph:
int CVICALLBACK zoom (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
int mod, left, right;
double min, max;
switch (event) {
case EVENT_LEFT_CLICK:
case EVENT_RIGHT_CLICK:
GetGlobalMouseState (NULL, NULL, NULL, &left, &right, &mod);
if (mod & VAL_MENUKEY_MODIFIER) {
GetAxisScalingMode (panel, control, VAL_XAXIS, 0, &min, &max);
if (right) {
min *= 1.1;
max /= 1.1;
else {
min /= 1.1;
max *= 1.1;
SetAxisScalingMode (panel, control, VAL_XAXIS, VAL_MANUAL, min, max);
// Place code here to zoom other graph
break;
return 0;
I tried this solution and it behaves differently from the original zooming: it doesn't respond if you maintain the mouse button pressed and on my machine some clicks are missed... but it works.
Hope this helps
Roberto
(3,515 Views)
Dear Roberto,
Thank you so much for your quick response. I tried out the code you provided and it worked like a charm!
--Marianne
(3,515 Views)
