LabWindows/CVI
Can my labwindows project control a running labview executable or any other 3rd party software?
I am writing a program in Labwindows that needs to execute/control a LabVIEW executable without operator intervention.  How would I go about doing this.  Is there a special messaging protocol in Labwindows that allows me to do this?  Couldn't find any example code to work from.  Thanks.  Any help would be greatly appreciated.
(3,774 Views)
You can do this via the ActiveX interface. LabView for example has an ActiveX interface, so you can control LabView or a VI via thsi interface from CVI.
Here you can find more information and examples:
http://zone.ni.com/devzone/devzone.nsf/webcategories/A247F2BD6FD11D8D862567A90058B72D
(3,748 Views)
Alternatively, you can use the system() (ANSI library) or LaunchExecutable()/LaunchExecutableEx() CVI functions to start a third-party application.
Martin.
Martin
Certified CVI Developer
(3,743 Views)
LaunchExecutable() function is the wise one to use.
Kumar.E
(3,734 Views)
anguyen741 wants to start AND CONTROL another application, for example LabView.
If you only want to start another application I agree with you Kumar, that LaunchExecutable is easier to use. If you want to control the application, LaunchExecutable lets you only pass parameters to the exe, nothing else. When the application is running, and you want to control it from CVI, then you have to use ActiveX.
(3,725 Views)
