LabWindows/CVI
CVI 8.0.0 (273): Error: An internal error occurred for which the cause is unknown. (Error code -41)
Whenn I try to build a distribution package, I get the following error:
*** Error: An internal error occurred for which the cause is unknown. (Error code -41)
*** End Error Report
(2,953 Views)
Hello Yannick,
See this thread.  We have seen this problem most commonly because of a few different driver dependency components not being upgraded.  The components are typically DAQmx support components for RT, or the MStudio patch as is the case in the thread I refered you to.  If you create a debug log (the thread will tell you how) and post it here, I can tell you which parts you need to upgrade.
Mert A.
(2,937 Views)
