LabWindows/CVI
EasyTab and LocalUI
Hi, I have created the .lwl file of the .uir file of my application, using the User Interface Localizer tool. In my application there is a canvas that I use for load panels for creating a EasyTab user interface. This panels are in the same .uir file of the main panel. My problem is that the string of the main panel changes accordly to the lwl file, but the string in the panels of the EasyTab are always the default string in the .uir file!
(3,174 Views)
As the functions from the "localize user interface" instrument driver (.fp) work panel based, not uir-file based, you hae to call the functions multiple times for every panel, so not only for your main panel but for all panels that are added to the Tab-Control also.
(3,150 Views)
