LabWindows/CVI
Can no create distribution kit on MS 6.0 CVI
When trying to create a distribution kit with Measurement Studio 6.0 CVI get the error: Create Distribution Kit Error 26022 for file(s) aat.msi Internal error. I try in 3 diferent computer and get the same result.
(3,427 Views)
In all likelihood, this is happening because you set the "Installation Name" field of the Advanced Options dialog to be an empty string.
This error is an oversight, and it will be fixed. In the meanwhile, if you really want the Application Title to be blank, you can simulate that by entering a single blank character.
Luis Gomes
NI
(3,427 Views)
This really answer my question. Thank you so much for your help.
(3,427 Views)
This solved my problem. I don't recall having touched anything in the Advanced Options, so I was going to have a hard time stumbling on to this solution on my own. Thanks.
(3,427 Views)
