LabWindows/CVI
Can not get MySQL to work from a System call
With this code I can get MySQL to launch but does not recognize it as a valid statement in my C# program. It just shows prints out its help file:
System
("Mysql –h localhost –u me –password=pw < LoadDB.cmd");
Message 1 of 20
(4,506 Views)
It works fine from the command line as :
Message 2 of 20
(4,508 Views)
Hey erdc3,
It appears that the System() command has been replaced with the Process.Start() command in C#. Here's an MSDN resource page on that command:
http://msdn.microsoft.com/en-us/library/aa326952(v=vs.71).aspx
I'd suggest trying that command. If you still have problems getting it to work, let us know!
Message 3 of 20
(4,497 Views)
 tried it out with the following:
public static Process Start(
string Mysql -h localhost -u me -password=PW < LoadDB.sql
but get a whole bunch of errors such as :
Undiclared identifier 'puplic'
syntax error,; found 'static' expecting ';'
Message 4 of 20
(4,492 Views)
May be you should try it in the appropriate forum... This one here is about LabWindows/CVI, not C#
Message 5 of 20
(4,488 Views)
I am trying to make this work in my LabWindows/CVI code. Am I wrong to think that LabWindows/CVI uses C#? If not, what kind of C programing is it then?
Message 6 of 20
(4,486 Views)
Yes.
ANSI C: http://en.wikipedia.org/wiki/LabWindows/CVI
Message 7 of 20
(4,482 Views)
Thanks, now I know.
But now knowing that, just what code in ANSI C should I use to execute a system command as shown in my first post?
Message 8 of 20
(4,480 Views)
There are three options:
If you want to wait for the program to exit, use the system () function in the ANSI C Library. If you want the function to return without waiting for the started program to exit, use LaunchExecutable (). If you also want to monitor whether the launched executable has terminated, use LaunchExecutableEx ().
Message 9 of 20
(4,477 Views)
I have used the LaunchExecutable () to successfully start up the data base, then what I do is send a command of:
 FmtOut (“%S”, “USE MY_DATABASE\r\n”);
To send to the command line and followed by a carriage return, and it shows up as such, but nothing happens. It does not give me the myscl> prompt. Back. I have to actually hit the enter key to get the prompt back, but the command never gets executed. But then if I just type in from the keyboard USE MY_DATABASE it works.
How strange.
Thank you for your support you have been giving me, I am almost there. Must be some formatting I am doing wrong here?
Message 10 of 20
(4,470 Views)
