LabWindows/CVI
Can not get MySQL to work from a System call
I am sorry, I don't know the answer...
What I would try is:
- LaunchExecutable ( "Mysql < USE MY_DATABASE" ); instead of FmtOut (“%S”, “USE MY_DATABASE\r\n”);
or alternatively:
- FakeKeystroke ( VAL_ENTER_VKEY );
Message 11 of 20
(2,214 Views)
erdc3,
I'd suggest trying the suggestions to add the USE MY_DATABASE command to the LaunchExecutable call, or to try other methods of sending input to the console.
I'm thinking this might not be the easiest way to work with your database if you intend to do anything more complex than opening it. We do offer a CVI SQL Toolkit that provides commands for working with databases:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/11128
Would it be possible to get a bit more information about what you're trying to do with the MySQL database? That might help us suggest the best approach.
In the meantime though, I'd definitely try adding the commands into the LaunchExecutable command.
Message 12 of 20
(2,201 Views)
Thanks Daniel-E for the reply. All I want to do is up load a CSV file to a data base. So all the code I would need to send to MySQL after loging in would be the following:
LOAD DATA INFILE 'c:\file.csv' INTO TABLE 'db.table'
FIELDS TERMINATED BY ','
LINES TERMINATED BY '\r\n'
Message 13 of 20
(2,197 Views)
Just out of curiosity: What happens if you try
as I suggested earlier?
Message 14 of 20
(2,195 Views)
Sorry Wolfgang, I meant to respond to your input. But when I use
It just throws back at me its help file list.
Message 15 of 20
(2,193 Views)
I don't have a MySQL server running here, so I cannot try it, but I remember that you can execute MySQL statements in a script file.
So may be placing all your SQL commands in that script file may work:  LaunchExecutable ( "mysql dbname < script.sql" ); could be that line feeds are interpreted differently if read from the script...?
Message 16 of 20
(2,190 Views)
Good call Wolfgang, but that just gives me the help list. For some reason it will only take the following command and respond to it:
LaunchExecutable ("Mysql –h localhost –u me –password=pw");
Message 17 of 20
(2,187 Views)
erdc3,
I think it might be helpful to use the LaunchExecutable command in a way that emulates the Windows command line. Here's a page from the CVI Help about the LaunchExecutable command:
http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/libref/cvilaunchexecutable/
By inserting cmd.exe /c at the front of the string argument in your LaunchExecutable command, it will open cmd.exe (the Windows command line), and run the rest of the argument as an input to the command line.
So I'm looking at some of the documentation for the MySQL command line tool, specifically this page: http://dev.mysql.com/doc/refman/5.5/en/batch-commands.html
It seems like you should be able to use a command similar to the following:
LaunchExecutable("cmd.exe /c mysql -h localhost -u me -password=pw <databaseFile.sql");
where "databaseFile.sql" is the text file containing your commands. The first line of this file might need to be a USE command to tell it which database to use--so if your database is my_database, you'd need to say USE my_database as the first line of your file.
Hopefully that will work for you--let us know!
Message 18 of 20
(2,175 Views)
Accepted by topic author erdc3
Thanks Daniel-E! that did the job. I can now up load the data from the Labwindows/CVI code and it does not show the logon/password needed to connect to the database.
Message 19 of 20
(2,172 Views)
That's great to hear! Good luck with the project, and let us know if you have any more questions!
Message 20 of 20
(2,166 Views)
