LabWindows/CVI
Can not get the proper angle value
I have drawed a circle on the canvas control, and want to capture an arbitrary point in the circle, where the point's coordinate is determined by the "GetRelativeMouseState()" function. The whole idea is this:  once click in the circle, I can get the coordinate of the clicking point by using "GetRelativeMouseState()", then drawing a line from the circle's midpoint to the point, expecting to calculate the angle between the line and the X axis. I post the sketch to explain how the process is treated :
the coordinate of the midpoint is (width/2, height/2), so if want to calculate the theta angle, I can get the formular: theta = atan((height/2 - yCoor) / (width/2 - xCoor)), there is a strange condition: if the line is near to the X axis (in fact, the line turn to angle exceed 135 degree (as to the counterclockwise) but there is a distinct angle between the X axis, the theta), I always get a zero angle value(the theta).
Please help whether  the "GetRelativeMouseState()" can provide an exact position?
David
(3,217 Views)
How are you calculating the angles? With some basic trigonometry and atan2 () function I always get the correct angles: take a look at the attached canvas.prj sample which I modified adding the necessary functions (click Draw Circle and check Angle drawing: when clicking on the canvas the program will draw the line and calculate the corresponding angle)
(3,207 Views)
