LabWindows/CVI
InstallPopup overwrite window topmost status
My CVI dll popup a main panel as topmost window.  That works fine.  Problem start when I need popup another dialog window on top of the main CVI window.  I used InstallPopup.  The popup window got a correct relation with the main window, but both CVI windows lost topmost status.  So they can be covered by the dll caller (LabVIEW).  When I close the popup window, the main panel get its topmost status back mysteriously.
When I call Set attributes for setting topmost programmatically, I got an runtime error, saying that I can't do that while the popup is running.
I did manage to get topmost back by Window API calls.  Don't know if this the right way.
Anyone run into this before ?
George Zou
(3,479 Views)
How are you removing the popup?
This post may be helpful.
NI FORUM LINK
(3,467 Views)
Thanks for reply ngay528.
My main panel is NOT a modal (popup).  I don't know how to make it a modal.  InstallPopup doesn't work in this case.  The caller is LabVIEW.
So I don't use RemovePopup.
George Zou
(3,435 Views)
(3,419 Views)
