LabWindows/CVI
Can not use the DBGetColChar (hstmt, 2, &str_arr,"") ?
I do not know why the command of DBGetColChar having the error. In my table Table1, column STRval (#2) Does any oneI have string values & I try to read them into str_val but it failed. Here are my codes:
char *str_val;
str_arr = calloc (100, sizeof(char));
 hstmt = DBActivateSQL (hdbc, "SELECT STRval FROM Table1");
 while (DBFetchNext (hstmt) != DB_EOF)
       DBGetColChar (hstmt, 2, &str_arr,"");         //   <---- ERROR
       InsertTextBoxLine (panelHandle, PANEL_TEXTBOX2, i , str_val);
      i++;
 DBDeactivateSQL(hstmt);
Does anyone know what is wrong? Thanks for any help
(3,647 Views)
Hi ATC_ATC,
What is the error message?  Does it fail the first time through the loop?  To make sure you do not call DBGetColChar when fetch failed, your while loop should be:
while ((resCode = DBFetchNext (hstmt)) == DB_SUCCESS)
Also, you have to free str_arr in every iteration of the while loop:
DBFree (str_arr);
Best of luck!
Cheers,
David Goldberg
Software R&D
(3,631 Views)
Hi David,
I found out my problem, since I search only 1 specific column, but I was looking for col2 (#2), instead of 1 ... it is Ok now. Thanks for help
*) But there is another problem with the   DBGetColChar (hstmt, 1, &str_val, "$");   ---> I try to retrieve currency into string, it shows only $56 instead of $56.78, do you know how to show it with 2 decimal point?
(3,620 Views)
Hi ATC_ATC,
The CVI SQL Toolkit Reference Manual has instructions on this:  [CVI]\sql20\LabWindowsCVI SQL Ref Manual.pdf
The relevant part is:
Format String:  $#,##0.00
Value:
210.6
Formatted Value:  $210.60
Cheers,
David Goldberg
Software R&D
(3,603 Views)
It works beautifully
Many thanks Smiley Happy
(3,596 Views)
