LabWindows/CVI
Cannot read data from keithley 6485
I am programming with labwindows to control keithley 6485.
However, READ?\n command does not work at all.
That command only works after I reset the keithley 6485 by *RST\n command.
If I change some settings (like measurement unit), then READ?\n command does not work.
Why I can use READ?\n command only in default setting?
(2,238 Views)
I think you are using LabWindows, but I can not understand these words.
Could you show me how you configured your code?
(2,204 Views)
