Cant build exe msi installer
I would like to create *.msi installer for my application. Ive build "Release" package and then I started to build new distribution. After sometime there are error occured. Ive spent 2 days to fix that but still, without effect. Please help me 🙂 In attachments there are screenshot from LabWindows and debuglog from Temp.
What more can i say, im using Trial version (so maybe thats the point). Previously I cannot start builded application from Release folder (there was an error about lack of DLL), but im fixed it by adding one path to PATH field in Enviorment Variable.
Cheers
(1,536 Views)
EDIT:
In log file there is an error:
> *** Error (-21): An internal tool or library returned an error.
Error Details:
> Error in MDF API function: _MDFBuildDevPart_Close
> Error in MDF::BuildDeveloperPart::Close.
> nmdkAddFile returned error code 26043
*** End Error Report
But I can't find anywhere such function, so it seems that this is "internal" code of LabWindows
(1,500 Views)
Accepted by topic author MichalZajac
Come on, no one from NI is not able to help me?
Guys, LabWindows/CVI is your software - and with log and description of problem, you can't even give me a bit of an answer what could have gone wrong?
I really got to the wall with that 😕
(1,468 Views)
