LabWindows/CVI
Changing Marker Size in Graphs?
Is it possible to change the size of the "markers" used when using
PlotPoint() in LW CVI 5.5?
I haven't been able to find an attribute that will change the size.
(2,949 Views)
Unfortunately, no, you can't change the point size, just the line thickness. You can use the shape plotting functions like PlotRectangle or PlotBitmap in lieu of PlotPoint.
Best Regards,
Chris Matthews
(2,949 Views)
