LabWindows/CVI
call dll function from static library
I'm using TestExec. When I want to run a test TestExec runs a
sequence file and the sequence file causes TestExec to load a library
file that has the functions that will be used for the test. I believe
the library file is being loaded with LoadExternalModule(). The
library file calls a dll that I've created to handle rs485 token
passing. The library loads the dll with LoadExternalModule(). So far
so good. However when I try to get a function address from the dll
using GetExternalModuleAddr() I get an error -25 (intialization
failure) or as the windows function GetLastError() puts it, error 126
The specified module could not be found. I know the dll is good
because I can create a simple labwindows application with a couple of
command buttons for LoadExternalModule() and GetExternalModuleAddr()
and I can load and run the dll functions just fine. It's only when I
try call the dll from an externally loaded library that I run into
problems. How can I call a dll function from an externally loaded
library? The solution must be in modifying the library file or the
dll. Changing TestExec is not an option for me. Help? Can I bypass
the CVI functions altogether and use windows functions LoadLibrary()
and GetProcAddress() to load and run the dll functions instead? What
is the proper way to do this? I tried this and got an unresolved
references error. Any help would be excellent.
(4,588 Views)
LoadExternalModule is NOT for use with DLLs directly. It's for LIB and OBJ files. You could use it with the DLL import library (.LIB) file, but not on a DLL directly. See the help for the LoadExternalModule function.
You can use the LoadLibrary()/GetProcAddress() method to load the library. This is frequently used by CVI programmer's and is the only alternative to using a import library (statically linked or loaded through LoadExternalModule).
Best Regards,
Chris Matthews
(4,588 Views)
I figured out that I can use use windows functions LoadLibrary()and
GetProcAddress() to load and run the dll functions instead of cvi
functions LoadExternalModule() and GetExternalModuleAddr(). What I
did wrong before was I put the dll in the folder my library file was
in and I should have put it in the folder TestExec is in since
TestExec is the application the dll is being mapped into.
aachess@yahoo.com (Kevin Houston) wrote in message news:...
The
> and GetProcA
(4,588 Views)
