LabWindows/CVI
cvi&sql&multithread
Hello:
I'm using LabWindows/CVI 6.0 with dBase 5.0 of SQL Toolkit v2.0.6
Are there some examples of multithreading?
Please advise me.
Thank You.
(3,240 Views)
There aren't examples that involve both multithreading AND SQL, but there are many examples on multithreaded programming in CVI under the directory cvi\samples\utility\Threading. There is also a great white paper that will tell you everything you need to know about Multithreaded programming in CVI. You can find it on your hard drive in cvi\bin\MultithreadingOverview.pdf.
Best Regards,
Chris Matthews
(3,240 Views)
