Changing folder order in project
This may be a dumb question, but is there a way to rearrange the order that the folders show up in a project tree?  It seems by default CVI has them in the order of "User Interface Files", "Source Files", "Include Files", which is fine.  However, I have an old project where the "User Interface Files" for some reason comes after the "Include Files" which is driving me crazy Smiley Frustrated.  How can I change the order that they show up?  There doesn't seem to be a way in the Project Tree and the Edit->Project... window doesn't seem to have a way to do this either.  Thanks!
(4,283 Views)
You should be able to drag and drop them directly in the project tree
(4,273 Views)
When I try that, I just get a black circle with the line through it.  That's pretty much the case if I try dragging and dropping anything on that panel.  Seems like I'm missing something obvious.
(4,268 Views)
Accepted by tstanley
This is not the most elegant solution but the "brute force" approach is to open the project file in a text editor, locate the [Folders] section and arrange the listed folders to meet your needs. Once the folders are arranged, rename the Folder keys numerically from 0 to n.
(4,262 Views)
Thanks.  Not the prettiest solution, but it worked.
(4,257 Views)
