LabWindows/CVI
Check com port
This is just what I needed. Thank you!
Message 11 of 17
(3,145 Views)
I used the dll and it will find a port if you know the number.  I have a device that enumerates as multiple comports.  windows assigns the ports as the next available port.  In windows, the device name is shown with the comport assigned in brackets (com24).  How can I scan for comports by the device name.  The device found in device manager is Telit mobile (USB3) (COM24).  I need to scan all the usb ports for "Telit Mobile (USB3)" to find the assigned port number (com24).  I used devcon in the past but it requires admin rights to run.  any suggestions?
Message 12 of 17
(2,965 Views)
This works great.  Can this code be converted to CVI?  I hate using dll's from other software platforms in CVI.  I need to be able to support production.
Message 13 of 17
(2,965 Views)
Martin has already posted the CVI version of the code: you can find it here
Message 14 of 17
(2,960 Views)
The code uses a setupapi.lib file.  how was it generated?
Message 15 of 17
(2,951 Views)
It is part of the Windows SDK
Message 16 of 17
(2,947 Views)
Hello, Thanks for the zip.
I want to know the name of devices.
Any suggestions ?
Message 17 of 17
(2,843 Views)
