Check the flux of printer's ink box
Hello ,
Want to check the ink box's flux , anyone could give an advise ? Thanks.
David
(3,117 Views)
Hi
The question was a little vague. I would like to know what application your trying to build, is there any hardware involed, is CVI the main program? If I understood correctly then you are trying to check the ink level of your printer catridge from CVI assuming that flux means fluctuation. Please let me know. Thankyou.
Robin D
(3,117 Views)
Yes, I use cvi as the main programming tools . flux means "runoff" . if NI have such board or card ?
David
(3,117 Views)
