LabWindows/CVI
ClearListCtrl & DeleteListItem- function not OK ??
Hello
I am using "ClearListCtrl " to free a list control, but after clearing it I cannot populate it anymore
in the same instance of my program.
After restarting it, it works, but also for first time only.
The same thing happens if i use "DeleteListItem(PANEL, PANEL_tag_list, 0, -1); ".
Am I doing something wrong?
(4,100 Views)
Hello Snoopy,
Can't tell what you're doing wrong. Would it be possible to give us some more information about the source code? I suppose you use the InsertListItem function to populate the list control? Do you get any errors when using the ClearListCtrl , DeleteListItem or InsertListItem functions (you can check this by declaring a variable that the function can set. e.g. error = DeleteListItem (PANEL, PANEL_tag_list, 0, -1);, and then check if error is set to zero)?
(4,101 Views)
That "PANEL" looks suspicious. Is it really the variable for the panel handle returned by LoadPanel?
(4,091 Views)
Hello
PANEL is actually the name asigned by CVI, I had no reason to change it.
So I continued with that name, as far as I know it is not a key word.
(4,071 Views)
Hello, problem solved, thanks for the quick reply.
Nice day
(4,064 Views)
Hi disregard the last post, problem was solved.
(4,062 Views)
