LabWindows/CVI
Interact with rs-232 (receive msg and enter response) using textbox in CVI
I'm trying to use TextBox to receive and response to UUT via RS-232.  I'm new to CVI and looking for some advices or examples.
My application is to receive a Bist test menu from UUT and then enter test selection to run and display test run results(similar to Hyperterminal, TeraTerm). Any help is very appreciated!
(2,946 Views)
I suggest you begin studying the RS232 samples distributed with CVI: you can look into samples folder inside cvi directory: even if simple, these samples hold all you need to begin communicating with some equipments.
After looking at them, I also suggest you to search the forum for rs232-related arguments: serial communication is a popular argument and you can find several resources on it.
Message Edited by Roberto Bozzolo on 02-01-2007 07:18 AM
(2,938 Views)
