LabWindows/CVI
Closing X in Graphical Array View without Function
when debugging the Graphical Array View is quite useful. However, the X of the graph does not do anything, see the figure below. One can close the graph by the adjacent X, so it's not a major inconvenience, but still it is a little bit confusing why there is an X if it doesn't do anything Smiley Wink
(5,279 Views)
Accepted by Wolfgang
Hello Wolfgang,
I understand you are referring to the 'x' in the Graphical Array Display tab area. That 'x' is actually the name of variable corresponding to the plot.
The tab can have a different name, depending on the name of your variable:
Best regards!
- Johannes
(5,254 Views)
Smiley EmbarassedSmiley Embarassed stupid me
thanks...
(5,250 Views)
