LabWindows/CVI
CmtInstallTSQCallback help
Hi i am using a thread safe queue but wish to execute the callback in another thread
so instead of passing
CmtGetCurrentThreadID() to CmtInstallTSQCallback I need to pass a thread id.
like
CmtInstallTSQCallback (tsqHandle, EVENT_TSQ_ITEMS_IN_QUEUE,
                                            600, QueueCallback, NULL,
                                            thread_id, &plotDataCallbackID);
How can I create a thread and get its id to pass to
CmtInstallTSQCallback.
Sorry if this has been answered. I can't find any examples of this.
Glenn Pierce
(4,084 Views)
Hi Glenn
I have been looking into the CVI functions for multithreading and I don't think you can find the thread ID of any threads other than the current thread or the main thread. There is a CVI function that finds the ID of the main thread, this is the CmtGetMainThreadID function. You may be able to use C commands to do this, however there is no specific CVI function that can do this.
Also, having looked at the functions, it seems that you can create a thread pool which contains threads, but I don't think you can create an individual thread. You can us the CmtScheduleThreadPoolFunction to assign tasks. The function will automatically choose which task is assigned to which thread. Another function you can look at is the CmtScheduleThreadPoolFunctionAdv, this allows you assign priorities to functions.
I hope this helps
Regards
Beejal S
NI UK & Ireland
(4,023 Views)
Here is some pseudo code for passing a thread ID for the TSQ callback. Hope this helps.
volatile unsigned int threadID = 0; // global variable for thread ID
volatile int quitThread = 0; // global variable to signal thread function
Main thread:
CmtNewTSQ
CmtNewThreadPool
while (threadID == 0) // wait for thread pool function to initialize its thread ID
    Sleep(0);
CmtInstallTSQCallback // install TSQ callback with threadID
/* do work */
CmtWaitForThreadPoolFunctionCompletion // wait for thread pool function to finish
//clean up
Thread Function:
threadID = CmtGetCurrentThreadID();
while (!quitThread)
    ProcessSystemEvents();
(4,010 Views)
