LabWindows/CVI
Converting a flat map in a globe
I'm searching something for making from a picture (*.jpg, *.bmp, ...) like this a ball. The Picture (in this case an earth-map) should tight the ball. The ball should be in 3D that I can roll the ball on screen.
Greets,
chemph
(4,851 Views)
Hi chemph,
a possible solution would be to use a 3rd party software to convert the picture to 3D and save it as VRML, STL or ASE file.
This file you can import into labview
Regards
DianaS
(4,828 Views)
Unfortunately there is no function to import such files in LabWindows/CVI but you can create a dll from the labview programm an use it in CVI.
Regards
DianaS
(4,824 Views)
Hallo and thanks for the replies! Smiley Happy
But what is a "3rd party software"? Are there any free-programmes or tools? Do you now any programm that you can command?
chemph
(4,822 Views)
Nobody knows any program? Smiley Indifferent
(4,734 Views)
