LabWindows/CVI
Converting a flat map in a globe
I'm searching something for making from a picture (*.jpg, *.bmp, ...) like this a ball. The Picture (in this case an earth-map) should tight the ball. The ball should be in 3D that I can roll the ball on screen.
Greets,
chemph
(4,466 Views)
Hi chemph,
a possible solution would be to use a 3rd party software to convert the picture to 3D and save it as VRML, STL or ASE file.
This file you can import into labview as shown in following link:
Regards
DianaS
(4,443 Views)
Unfortunately there is no function to import such files in LabWindows/CVI but you can create a dll from the labview programm an use it in CVI.
Regards
DianaS
(4,439 Views)
Hallo and thanks for the replies! Smiley Happy
But what is a "3rd party software"? Are there any free-programmes or tools? Do you now any programm that you can command?
chemph
(4,437 Views)
Nobody knows any program? Smiley Indifferent
(4,349 Views)
