Code refactoring: "include-what-you-use" tool
Code refactoring is a common need for C developers and availability of eiter automated or semi-automated tools can be really helpful.
Since LabWindows/CVI now uses llvm+clang, probably a tool like "include-what-you-use" can be integrated.
This is the github page for the tool.
From the documentation:
"Include what you use" means this: for every symbol (type, function variable, or macro) that you use in foo.cc, either foo.cc or foo.h should #include a .h file that exports the declaration of that symbol. The include-what-you-use tool is a program that can be built with the clang libraries in order to analyze #includes of source files to find include-what-you-use violations, and suggest fixes for them.
The main goal of include-what-you-use is to remove superfluous #includes. It does this both by figuring out what #includes are not actually needed for this file (for both .cc and .h files), and replacing #includes with forward-declares when possible.
Is this tool available in CVI?
If not, I can open a new suggestion in the Idea Exchange Forum (if CVI is actively developed - I have some doubts Smiley Sad)
Vix
Using LV from 7
Using LW/CVI from 6.0
(5,280 Views)
I certainly will support your suggestion Smiley Happy
(5,278 Views)
I will support it as well
(5,263 Views)
Accepted by vix
Here you can find my suggestion in Idea Exchange forum.
Feel free to give your kudo if you support the idea.
Vix
Using LV from 7
(5,249 Views)
