LabWindows/CVI
CodeBuilder
I am a new CVI user with a new install of 9.0 and am working through the sample1 tutorial.  I completed the construction of the .uir on page 2-5 of Getting Started.  Page 2-6 says to use CodeBuilder.  I may be blind but I can't find any reference to CodeBuilder or a menu option for Code>Preferences...  Or is it possible that I have an incomplete install?
Chembox
(3,628 Views)
Accepted by chembox
Hi chembox.
The functionality is there in the menu system, but the word CodeBuilder is not (as far as I can see).
When your .uir file is open and has focus, click on the Code menu, then Generate. The skeleton code will appear in the window of your selected Target File (this can be set via the Code menu also).
For more information, search for "codebuilder" in CVI Help.
Colin.
(3,616 Views)
